deli
Hi I am installing a 22 amp water heater under the sink and cant get an internal cable back to the consumer unit so the only route is outside either under ground or clipped around the house my question is , is this within regs and what rating cable should be used, the distance is a Max 15meters also would a 13 amp fused spur be sufficient to install the heater into I have a spare 30amp mcb on the consumer units thanks
