C
cal_dood
i did some outside lights not too long ago and the client who was also a sparky wanted me to gland the armoured into a conduit box, then take the inner sheath straight through and out the other side (through a compression gland) and into the light fitting. Is this a good practice or should i avoid doing this?? this obviously meant that the boxes weren't earthed apart from what earthing the armouring on the cable gave it.
