I
ian81
Im after some advice, Weve installed about 10 systems all the same mitsubishi 225w panels x 6, sunnyboy sb1200 inverter. A representative of the scheme that these were installed for had thier own system installed by another company who earth bonded the array and said that all of our installs were incorrect and should be bonded. I spoke to NICEIC and they said if it was above 2m odd, according to regs cant remeber exact height without checking!!!, then we needent worry and NAPIT's response was almost exactly the same. I found out that they had ran a 10mm earth cable. im in a bit of a grey area at the moment as im not sure what is right and what is wrong. Some people are saying it needs to be done others are saying it doesnt !!!!!!!!! Any help would be much appreciated.
