Array size,Inverter size, what do i put on fit application | on ElectriciansForums
Discuss Array size,Inverter size, what do i put on fit application in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Midlands
HI all,
Im installing 16 x 240w panels and a eversoler 4000tl,
so i have 3.8kw system, whats the maximum allowed i read somewhere 3.68
so what do i put on the FIT application and when notifying the DNO.??
thanks
Grand
It all depends on your Dno phone them up and discuss it with them I did this and we fit Sma 4000Tls all the time and I've never been asked to limit them to 16 A, just to change the frequency settings to G59
you just do an application before installation and you'll need the acceptance letter first ,WPD will at present accept them under G83 using G83 type tested inverters although I've been told this will change soon and they will require a G59 application in the new year 2nd March 2012
if you don't have time then you'll need to limit the inverter and notify afterwards
The ES4000 is G83 as you know, it capped at 16A - on G831/1 it asks for Amps under normal running conditions just put 16A - and on Fit Application put 3.68Kwp as TIC & DNC
Reply to Array size,Inverter size, what do i put on fit application in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
