Asbestos cables????? Rewire periodic inspection | on ElectriciansForums
Discuss Asbestos cables????? Rewire periodic inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
London
Experts opinion required.
Ask to add some addition fittings to a lighting circuit within a shop. Opened up the consumer unit to access the circuit. And noticed the tails from the service head to the meter and from the meter to the consumer unit look very suspicious. I have experience with cables that have a similar appearance and these have been asbestos.
What's your opinions. And what should my next step be?
[ElectriciansForums.net] Asbestos cables????? Rewire periodic inspection
They look like VIRs And if they are they should definitely be replaced. Not ever heard of them being asbestos as far as I’m lead to believe how were the other cables you mention confirmed to be asbestos?
A specialist company was employed. Who verified it through sample tests.
Not under the scope of works per se, but a word with the client about VIRs serviceable lifespan and degradation would be an appropriate conversation to have
I have brought this to the clients attention. Future works could be replacing the consumer unit. As in a poor condition. Mismatched Mcbs and circuit being doubled up in 1 mcb
Don't suppose you have any pictures of them do you?
Asbestos in cables wasn't something that came up when I did my asbestos awareness and non-licensed works training (fuse boxes, yes, cabling no), a picture may be nice to pass on to the training company.
No, these are normal VIR cables which do not contain asbestos. Rubber insulation overbraided with cotton impregnated with a preservative compound. Asbestos was only used where heat-resistance was required, i.e. not in normal installation cables.
I've got lots of asbestos-insulated cables of all kinds, as they were common in theatre lighting equipment due to the temperatures involved, and certain older switchgear and appliances. Most of them 'look' like asbestos, typically they are not impregnated and quite friable. I can post pics later.
Reply to Asbestos cables????? Rewire periodic inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
