H
Hanch123
Hi guys, had a simple job fitting an inline fan today, I drilled a pilot hole in the sofit and I'm a bit concerned its asbestos, it's painted white although the actual material is a grey/blue colour and not very easy to drill. I only had a crappy paper mask and didn't want to risk it, I've not had much experience with asbestos, am I right in thinking it might be as I've heard it can be a common thing on sofit boards?
You'll know in 40yrs ish ;).... asbestos is large fibre based in the air born reality if you had a mask on your probably ok even the cheaper ones although those knowingly working in it use a higher grade mask because of the high exposure.
Cheers, gonna drill it today with a decent mask. The Koreans are probably gonna blow us up within the next 40 years so I'm sure it won't matter if I've breathed a little bit in
Errrm! If it is asbestos id not be drilling it at all until you have ad it confirmed and risk assessed.... there are many different forms of it and it only take one partical to settle into your lungs to put you at risk, last time i was suspect i told the customer who called in an expect who thus confirmed i was correct ... he explained it was a low risk form and i could drill it with appropriate mask and by wetting it down.... have coe across it where i wasn't allowed to damage it in anyway as it was highrisk.... this was a foam type lagging on pipes.
Its also been linked to your genes as to how prone you are to get it.... my grandad was exposed to it on 1 occasion with 3 other blokes at work wen ask to knock down a shed --- they all died from it within 40yrs so i probably have the gene that puts me at risk.
No he wouldnt be ok if he had a mask! He drills through the asbestos, the fibres get stuck to his clothes and he then comes home so he and his family can inhale it, maybe even pick up and cuddle his newborn baby covering him in asbestos fibres, he then puts his clothes in the washing machine where it can spread to everyone else's clothing and increasing the risk. But as long as he wore a mask he'll be fine....
If you ever suspect that you've disturbed asbestos then leave the site and dont return until professionals have dealt with it.
Good point there....... hard to believe in my apprenticeship it was barely mentioned and little time was spent on the issue i suspect nowadays its alot more emphasis on the dangers of it, we had a big brake companies employing alot of our town in the 60's 90's and most of the staff there have met an early painful demise because of it....
ive done 2 awareness courses in last 12 months, infact you are supposed to do one every 12 months to keeps it fresh in your mind. whilst i still wouldnt be sure i could identify it i know when it could be and it sounds like you found some. get it checked, its not safe for you to work on and must be done by a specialist as any dust left behind could still be detrimental to your health.
its gonna cost the homeowner quite a bit
No, you are probably not ok.
If you suspect asbestos. You stop work immediately and inform the relevant people.
If you do this kind of work on a day to day basic then you should do some training to make you more aware, especially the user who posted earlier claiming ignorance!
I complete my asbestos training each year having just updated mine two days ago.
A fact stated on the course is that asbestos related illnesses kill approx 4000 people each year and is the biggest known killer.
My first week at a previous company I worked for was to turn two store rooms in to one office with dado all around and new lighting etc.
I ripped down the entire ceiling (false ceiling) and stayed in the dust filled room without a mask for the whole period that I worked there. About 6 months after that I sat my first asbestos awareness course..
I'm 99% sure the ceiling tiles I removed and smashed to bits and binned were the ones shown as an example in a video.
Scary stuff.
When I was a young lad i was working on a new boiler (10 ton tank) heated by steam. The foreman I was working with nodded in the direction of the laggers working on the pipework and said they will be dead by the time they are 40. Its the asbestos in the lagging he said. That was the late 60's and we are still having problems with it today. I should add there was no such thing as PPE in those days and not much H&S either.
How many people wear an asbestos rated P3 mask when cutting their holes in the kitchen or bathroom artex ceiling?
Some artex back then contained asbestos..
Couple of different types of it, we came across it the other day in oil tank store rooms, weeny sure so asked for a register with premises officer and it said in book the tiles on roof were asbestos but didn't mention ceiling, but the guy we met that morning for meeting said il have look il know and it was a mild one. Anyway no drilling. Job on hold now
Steer clear of it my old fella was or is a spark like myself he's got the better one pleural placks struggles with his breathing at times but he's lost a few of his work buddy's to this over the years if you no its there walk away there's money to be made else were
Asbestos
Hanch123,
Farmelectrics,
