Ashp external wiring | on ElectriciansForums
Discuss Ashp external wiring in the UK Electrical Forum area at ElectriciansForums.net
Liverpool
Anyone installing ecodan heat pumps? Best cable type for wiring from rotary to heat pump unit? Trying to stay away from swa due to limited space with security cage.
As above - either NYY-J or H07R-NF. The latter is more forgiving around bends!
That’s really interesting. Does it have a special sort of boot gland to separate power from data at termination?
No it goes through a waterproof unit, or a stuffing gland if not for submersible units and then split out in the connection housing. I would say control voltages not data but if I can find out who actually manufactures it I will let you know as we can get pretty much any configuration we want.
Reply to Ashp external wiring in the UK Electrical Forum area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
