Asked to notify DNO of heat pump installation plumbing advice | on ElectriciansForums
Discuss Asked to notify DNO of heat pump installation plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Asked to notify DNO of heat pump installation Recently had job where could not get Electrical Installation Certificate completed because we had not got approval from DNO for the installation of 4 7kwDaikin air con units. seems they sometimes are not classified as heat pumps, but trying to get clarity. What have you found>
Asked to notify DNO of heat pump installation to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Asked to notify DNO of heat pump installation plumbing advice in the Plumbers Forums area at ElectriciansForums.net
N
Air Source Heat Pumps I have been thinking of going on this course but my only reservation with it is reaching out to the right clientele, has...
Nwalky
N
M
Heat pump hot water cylinder Has anyone fit one of these? A hot water cylinder with a mini heat pump on top with ducts for air in and out. Heat...
Matt0029
M
