asking a question in DIY | on ElectriciansForums
Discuss asking a question in DIY in the DIY Electrical Advice area at ElectriciansForums.net
Y
yasser
Hello Boys, I want to ask a question about fitting a cooker switch and I am presuming this should be done in the DIY section or do I post here and someone in admin moves it over once it been checked (as i'm still a new boy). Thanks.
fire a quick private message to any admin and request access to the diy forum. Marvo+sintra are usually about most often ☺
DIYer. I think if I was an actual sparky I should know this. Mind you saying that, just had a gas boiler fitted by a registered installer and it was wrong.
and you know this how? have you been a gas safe engineer previously?
oh, and your welcome to the answer to your original question btw.
Get an Electrician around to do it and that will stop the risk of the house burning down if you do it.
I know this because a gas safe inspector has reported it as being wrong. Its quite simple really. Now, did you want a stool for that horse of yours
hung like a horse.... you should be:
[ElectriciansForums.net] asking a question in DIY
You have permissions to post in the DIY forum.
I've moved this thread so you can just post your question below if you like.
Reply to asking a question in DIY in the DIY Electrical Advice area at ElectriciansForums.net
Thanks, I was reasonably confident but nice to confirm. That was the original install getting power to the outbuilding, done by an electrician we...
Often in old wiring, live to the downstairs switch, then in twin (or twin & earth) the two switched lives to the upstairs switch, and a single...
