Assement for Elecsa Part P | on ElectriciansForums
Discuss Assement for Elecsa Part P in the Business Related area at ElectriciansForums.net
T
tomaz66
Hi newbie here!
I'm looking for advice. I am installing a new c/u and some new circuits for a customer which I intend to use for my part P assement and I have the following issues:
1)
The lighting circuit has t&e cable but the earth has been cut out at almost every fitting! Should this be rewired or can I still connect this and prove safe with class 2 fittings? if I can't do R1+R2 what can I do?
2)
The house only has a single ring main suppling the whole house customer is talking more sockets and then probably will want to spur off them.
Does the 100sqm rule for a ring main automatical apply as soon as I change the c/u and or add sockets I which case I guess I should just rewire with 2 or 3 new rings.
3)
House was built end of 60's cable is multi-strand pvc could it be original? looks in very good condition.
I guess this is showing my lack experince but theres only one way to get it!:confused:
sounds to me like a rewire will be the better option, you could run seperate earth in for lights or note as class 2 only as mentioned although not my prefered method.
you will require division of the installation across rcds so it would be rcbo for the circuits as they stand,
as a minimum i would rewire the lighting and add seperate ring for kitchen and cooker circuit although (depending on condition) prob insist on a full rewire
as its for an assesment i wouldnt advise just a cu change as the install stands.
Reply to Assement for Elecsa Part P in the Business Related area at ElectriciansForums.net
This situation is not uncommon and is absolutely nothing to lose sleep over. There are plenty of properties sold without the 'required' electrical...
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
