R
rapier
Evening guys,
Just doing some digging around, im going to apply to niceic DI and for my smaller job i need to add a double socket in at home ill be spurring of the ring but im the spur will be out the ccu as the socket is at the back of the ccu and down the wall.
Is this job acceptable?
The only issue i have is that my ccu is a 6 way steeple and a 30mA rcd as the main switch is this acceptable or should i change it to a main switch? I suppose at least the installation as a rcd on your thoughts would be great guys.
Cheers
Cheers
