S
Spec
Hay guys new here...
I'm going to been given some plaster in down lights to fit by my client. They are made by Astro. Has any body any experience with these fittings. I've fitted the Collingwood version many times. They are a 2 part fitting Bezal and an led unit with built in driver connecting to the main wiring with a in line plug and socket arrangement so in the event you need to get to the terminals you simply pull the fitting down and disconnect the plug. Simple. This Astro fitting once plastered in the ceiling allows no chance of ever getting back to the connections... And they are not maintenance free. What do you guys think??
