Hi All
I would be very grateful if anyone has experienced and failed Astro Terra 28 (or others) LEDs. I have recently wired parallel and series over the years but have stumbled recently on how 6x 1w leds failed using a 5.95-10w 350mA constant current led driver. I have tested the circuit which is now tiled in and it tests fine at each of the six light locations showing relevant +ve -ve voltage. The fittings initially worked for 5 mins then nothing. I have tried another led driver and nothing... They are being shipped back but initially I am the cause " have you hot wired them ? etc etc" .....another 3 out of 4 did not work out of the box on another switched circuit with only one led left working ( different driver 1w-9w rated). I am just looking for any experiences with Astro lighting led products even if you have used their other products.
many thanks in advance.
(When ur dead U dead):mevilrun:
