Aurora inverters? | on ElectriciansForums
Discuss Aurora inverters? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi,
Anybody got experience/concerns with the Aurora brand inverters? I've only ever put in Sunny's but the people at Navitron seem enthusiastic..
Trouble is, every inverter I've seen all promise to do the job but we won't find out for another 5 years which ones use the really cheap components.
to be honest i couldn't tell you about 5yrs time, but what i can say is i have installed aurora inverters and find them a very good inverter with good technical help if needed.
Aurora inverters are made by PowerOne a company in the power business for many decades. Main advantage from SMA is that they have two MPP trackers giving you more flexibility with your string config. Also their voltage range is quite wide so they can perform very well in more northern parts of the UK.
Reply to Aurora inverters? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
