Aurora M10 problem | on ElectriciansForums
Discuss Aurora M10 problem in the UK Electrical Forum area at ElectriciansForums.net
sparky1224
Hi
First post on here,
Have recently replaced 5 large eyeball lights in customers kitchen with aurora m10's non dim with the large bezels and all worked well for 2 weeks then one stopped working completely, 4 lights are on 1 switch and 1 lights on another this was the one that stopped working. Good voltage etc so light replaced under warranty and it was fine for 2 weeks then the same thing happened aurora seemed to say it may be because its only 1 LED on a switch although they don't recognise this as a fault ! which i can't see being a issue anyway as no dimmers causing issues here so moved light to same switch as the other 4 lights and it has been fine since touch wood...... any ideas??
Nathan
Dodgy switch with arcing contacts or poorly terminated.
Reply to Aurora M10 problem in the UK Electrical Forum area at ElectriciansForums.net
Also posted in DIY. strange one in my kitchen. 3 sets of 2-way switched mains GU10 Philips down lighters. ( no dimmers) Have been fine for...
