Blitzem
Is it possible to have a 12volt battery, have it reduced to 6 volt to be compatible with a 6 volt system and still be able to maintain the 12volt battery by way of an inverter or something?
Discuss Auto - 6 volt with a 12 volt battery in the Auto Electrician Forum area at ElectriciansForums.net
Preserve a 6 volt vehicle system but have the benefits of a 12 volt battery like running accessories and using a common battery between vehicles.It is possible, however it will be less efficient because of the losses in conversion and expensive if you need much power.
What is the application?
or buy 2 x 6V batteries connected in series. same principal as HGVs with 2 x 12V batteries to get 24V and 12V.
Reply to Auto - 6 volt with a 12 volt battery in the Auto Electrician Forum area at ElectriciansForums.net
