J
Jon Hodgson
Hi all, I have a bit of a problem with an automated gate system one of the main problem is I can't find a manufacturers name on any of the equipment theres nothing on the PCB only thing I can get its the name of some of the parts manufacturers.
The issue with it is that the gate was opening normally then it stopped, I believe that its one of the relays that has gone down on the PCB
as when you connect the safety sensor to the board it begins to start a relay clicking, and if you remove the sensor and link it out it does the same thing. But im at a bit of a loss on how to test out the relays as Im not that on the ball with electronics
Relays in question are Shori S7-12 datasheet is here http://124.219.27.219/big5/maker03/htm/PDF_new/S7.pdf
If I can pin point the culprit I'm looking to replace it.
Any help or suggestions that you can give are greatly appreciated
