Hi guys,
I am quoting for the above on a job they require five of them. There might be a simple answer which I'm overlooking...
Five heaters fed via own rcd cu, the cu would only be live during off peak? Am I correct in this bit or do some meters have built in timer so in effect heater cu being live at all times and cheaper rate switches in automatically which reduces the cost of the storage mode of the heaters?
Otherwise how else would the convector option of the heater work if rcd cu dead during peak times?
Any help would be great thanks!
I'm probably over looking something but I can't see where
