Automotive Relays in series | on ElectriciansForums
Discuss Automotive Relays in series in the DIY Electrical Advice area at ElectriciansForums.net
Upstate, SC
I have a specific scenario where my new spot light/flood light pods have three wires feeding them. (Black-Ground, Red-white LED, Yellow-Amber LED) as you can imagine I’d like to have a simple operation to use on or the other but only if the fog light switch is active essentially giving the go ahead to the pods to them be selected for the desired output color.
Here’s what I’m thinking and please tell me if this would or would not work and if not is there a viable solution?
The existing 4-pin Tyco relay relies on the factory fog lamps switch and works fine.
I’m thinking if I take the wire coming from Pin87 out of the existing relay and rebuild it in a slightly heavier gauge wire to feed the pin 30 of a neighboring 5pin tyco relay I can then run my switched 18ga from within the cab to toggle the colors between the 87 & 87A pins.
I hope that I’ve explained it so that you can easily understand what I hope to achieve, if not please feel free to ask questions.
Do you need to say which vehicle it is?
Is this one of those cool fogs that have "angel eyes" (rings) and "devil eyes" (domed wide angle lens) inside them?
As if my handle doesn’t give the biggest hint. The pod light above the winch is the one I’m referring to.
I don’t foresee any issues with using a relay to conditionally apply power to a second relay but I’m also just an avid DIY’er and seeking others advice.
  • [ElectriciansForums.net] Automotive Relays in series
Reply to Automotive Relays in series in the DIY Electrical Advice area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
I guess the easiest way would be to run a supply from ignition /aux via a relay that drops the supply when the lights are on.
Check your car fuses using a multimeter to ensure they are properly connected and functioning. Refer to a guide on how to check car fuses with a...
