Avantech downlighters | on ElectriciansForums
Discuss Avantech downlighters in the Electrical Tools and Products area at ElectriciansForums.net
Exeter area
Has anyone fitted the GU10 firerated downlighters supplied by Avantech? Come from a trading co called red arrow.. not prefitted lamps but fit your own halogen/LED which I prefer because different people have different preferences on colour, beam angle etc.
They sent me some info on them, they looked ok and they only ÂŁ6 each plus vat..
What attracted me to them, apart from the price, was they are diecast twist n lock fronts and the wire terminals are PUSH FIT! it really bugs me that with JCC fittings for instance, one has to use two different screwdrivers to undo then refit 6 screws in each light.
I ordered some, arrived today and am quite impressed.. not a screw in sight! - there is a chunky terminal box which pushes onto the can side clip once wired up, all very sturdy; the cover is a push fit latch which snaps open with a small flat blade, there is accommodation for a pair of wires into each of L1, L2, N, and E ; the wires-in are strain relieved by the plastic moulding so there is no fiddly clamp to screw down; the lid then snaps shut.
The can is 90mm high and the hole dia is 75mm for fixed, 90mm for tilts. Alleged to be tested to BS 476 for fire (90min) and BS EN ISO 140 for acoustic.
I also bought two types of LED lamp to try out with them, 5W and 3W, both good prices of ÂŁ3.25 and ÂŁ2.95
Just wondered if anyone had experience of fitting and using these, as have not wired any up in anger as yet but so far they look like could be a real time and cost saver..
Cheers..
[ElectriciansForums.net] Avantech downlighters
photo of the inside of terminal block..
It baffles the hell out of me why most manufacturers don't include push fit in their downlights. It's not as if it's new technology or going to increase the cost significantly.
Reply to Avantech downlighters in the Electrical Tools and Products area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
