J
Joe79
I was after the opinions of other Electricians on pay for PV Solar work. I'm on ÂŁ120 per day before deductions. I have to travel 2-3 hours to most jobs. I'm the only Spark on the job and I need to fit the inverter, isolators DC side, do the AC cable run and fit the isolator and a new board if needed and then test and commision the work along with taking photos of all the work done. If the bonding of incoming services has not been done or is less than 10mm csa, then I also need to do this along with upgrading the meter tails to 25mm csa if they are under and most domestic properties need one or the other, or both. I'll be honest, I'm struggling on my own to get all the work done and although on rare occasions you get an easy job, most days i'm doing 12 hours. Any opinions?
