AVO MEGGER Lt5 Maual? | on ElectriciansForums
Discuss AVO MEGGER Lt5 Maual? in the Electrical Tools and Products area at ElectriciansForums.net
I
ian65
Hi every one i am looking for info ie. manual for a Megger loop tester.
I have bought it and i don't expect it to do too much but would like to find out a bit more on what it can and can not be used on? I am under the impression that this meter will not work when a circuit is RCD protected, i can try it out on my consumer unit but it has the old style fuse so i can't proove a point there.
Any replies welcome thanks Ian
i had one of them a few years ago. all it can do is measure EFLI on a non-RCD protected circuit. if you want to test an RCD circuit, you will have to link out the RCD while testing. there are 2 ranges on the LT5, 20ohms and 200ohms. you would gewnerally use the 20. the 200 is for TT systems where the EFLI is generally above 20ohms.
Reply to AVO MEGGER Lt5 Maual? in the Electrical Tools and Products area at ElectriciansForums.net
If properly designed as "frost free" then it won't. As i described above, such freezers typically have a finned heat exchanger (HE) with a fan...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
