I have an awkward customer who moans about everything
They had a new kitchen fitted and had a cooker cable 6mm already in so used that for a work top hob and oven. I used one 45amp isolator switch to switch both appliances on both wires from switch in 6mm protected by a 32amp rcbo. Recently his cooker was fault and got a cooker expert out to fix it. Faulty fan but this bloke said that the cooker needs to be protected by a 13amp fuse as stated in manufactures instructions. Now the customer is saying we bodged it and want a sfs feed off the 6mm to feed the cooker. And work to be done unpaid as our fault. Is there any regs that I could use or am I in the wrong
