Last we job today was to wire one of the fans above with speed controller.. Seemed all straight forward as the mechanical guys supplied and fitted it. When I went to connect to the fan the wiring box is inside the middle of the fan, I reckon the fan should of been flexed with 5c before fitted , has any if yous come across this, my only option now is to try get Down cavity and drill a hole to try and get to Middle where connections is.
- - - Updated - - -
It's about 300mmx300mm
- - - Updated - - -
