been doing some domestic testing for a freind of mine who has his own firm now i allways use to use b type breakers in domestic dwellings but ive noticed quite alot of c type recently on theses tests your thoughts
Used Type C's on a rewire sometime ago. Loads of halogens installed, so instead of going for the standard of type B MCBs then it tripping everytime a lamp blows, thought i'd fit type C MCBs.
I designed the circuit so knew that my Zs would easily comply with that of a type C.
what can i say, you guys know as much as me..
If your lamps were selv then the inrush on the transformers would be given extra allowance with a type c, if they are standard 240v GLS or GU10's well any filament lamp then your thinking it reduces tripping when lamps blow is incorrect, as the filament collaspes it leaves an ionized path which has zero resistance and creates a short circuit long enough to trip the mcb irrespective of B,C or D types the time curve is instant on a short with high ampage.
in short its a short when lamp blows...
Regardless of all the impressive technical explanations I've found changing type B's for C's where GU10's are fitted has dramatically reduced or even eliminated nuisance tripping when lamps fail.....Good enough for me.
