back box cutters | on ElectriciansForums
Discuss back box cutters in the UK Electrical Forum area at ElectriciansForums.net
davek
Hi all
Has any one used the armeg back box cutters, are they worth buying on a rewire of a old house ie brick walls. Also are the chasing chisels any good. The house has some large old coving, which hopefully I can manage not damage too much.
Regards
Dave
Brick and block are fine, stone forget!! I've got one, and its OK but half the time its just as quick with a hammer and bolster.
I've never heard any great things about box sinkers to be honest.
I always use a combination of lump hammer, bolster, scutch chisel, and sometimes if there's a lot to do the SDS chisel.
With the covings, take your chase out up to the coving then drill with your longest drill bit behind the coving within the chase. The longer and thinner the drill bit the better as it helps to get a bit of "bend" on it.
I hear lots of good things about chasing machines, but I personally don't use one.
they are not really worth the money to be honest, SDS chisel or by hand doesn't take alot longer. I have a worx handycut I use if there is a lot of chases up to do, a lot lighter than a chasing machine to be running up the wall all day. Generally that's by SDS chisel or hand/labourer too tho.
I bought a set from Toolstation a week ago. Cost ÂŁ80 for single double boxes and circular cutter.
Its garbage and is only good for thermalite blocks.
Scutch bit in SDS or bolster n chisel will prevail.
I will be getting a refund Monday!
Box cutters are crap, just chain drill and knock out with scutch chisel
also wall chaser and vacuum
all the chasing gear youll ever need
used an angle grinder once years back, i think the dust still hasnt settled
Consensus is about right,i think. Funny how tool show demos' are sinking boxes in a section of Battenburg...Being persistent in harder material,with box sinker,can result in much plastering or pushing bricks "through". Only item that impressed me,at a recent show,were a set of TCT hole cutters (Starrett style) which could be "stacked",resulting in an easy clear-out,they worked at slow speed,and materials at show,seemed real world enough. Glorious success was achieved at a friends,when we managed to sink two back to back 35mm switch boxes,in a brick-on-edge wall,at his 1937 semi. With hindsight,the hour two of us spent doing it was not an example of high productivity...:conehead:
Reply to back box cutters in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
