Back box lugs and cross threads. | on ElectriciansForums
Discuss Back box lugs and cross threads. in the UK Electrical Forum area at ElectriciansForums.net
FatAlan
Trainee
Nearly Esteemed
Supporter
Surrey
Is it worth while re tapping lugs on back boxes? Just ordered a 3.5mm tapping tool as I had an issue at the weekend with the head of a screw shearing off and the resulting pain in the neck hassel of getting the remaining screw shaft out of the lug. This must be a very common problem. Is re tapping effective bearing in mind there isn't that much metal there in the first place?
If tapping out the lug is unsuccessful, you can also try drilling out the back of the box in line with the lug and use a long screw to reach right to the back. I have also managed to replace a lug before (obviously not a fixed one). I have also placed the threaded section from a drylining box behind the lug and managed to catch it with a screw and used that to secure the switch/socket. I found some of the older backbox screws my dad gave me are tighter in modern back boxes and seem to work without tapping.
On the odd time I have a duff thread I just use the junior hack saw to score the end of one of the screws alone the shaft. It makes a crude tap. Screw it in and it re-cuts the thread. Normally works.
In conclusion, when you haven't got one you wished you did and when you've got one it doesn't matter whether the thread is good or not - get me?
Useful to squeeze the lug with mole grips first, then re-tap. If you want to be nasty you can use a 3.5 nut and spring washer, nips up fine if you put a plug into the socket and pull it gently forwards as you tighten the screw. Guaranteed to drive the next person mad, specially under a kitchen cupboard.
Last time I used taps and dies was aged 11 in metal work when making a screw driver. That was after the regulation key fob in metal which had followed the regulation laminated acrylic plastic key fob.
Reply to Back box lugs and cross threads. in the UK Electrical Forum area at ElectriciansForums.net
