V
vibetime
sorry if this has been covered , but i have researched and got many different views.
so, what is a back feed and how do they happen ?
Discuss back feed explained in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An unwanted interconnection between circuits.
Classic example upstairs and downstairs lights - and the landing light arrangement.
These days, we run T&E to landing switch from light, then 3&E between switches.
Olden days, they picked up a L from the hall light switch (as part of 2 gang switch)
Then ran T&E between switches
Then ran a single L to landing light, and a single N from landing light to nearest upstairs light.
Joe Spark comes to work on upstairs lights, locks off the MCB. Prove, test, prove...
He has got a bunch of wires in his hand, feeding them through the base of new light fitting.
But someone switches the landing light on (it doesn't come on) and.... many of those wires in Joe's hand are now live as he has broken the neutral and 60 Ohms worth of cold filament in the landing light won't limit the current through his body!
It's not unheard of to find unwanted interconnections between other circuits... I've found them between cooker circuits and ring finals!
Simon.
This is incorrect as it is also a statement used where the main supply has been disconnected and a temporary supply is connected to keep equipment running eg When you have a HV supply you may need to work on the transformer and to keep the LV equipment running you would connect a generator to the LV side and this is known as back feeding.
Can someone clarify it , if it was in a normal heating circuit for example ?
people have different views on this as described above.
I understand borrowed neutrals.
Reply to back feed explained in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
