View the thread, titled "Back to back consumer units" which is posted in UK Electrical Forum on Electricians Forums.
Hi I have come across an unusual situation but my brain is not working..... (I am an electrician btw)
I am putting in a second consumer unit (garage) and it just so happens million to one that the new (second) consumer unit is going on the wall that is 100% perfectly directly the other side of the main CU. In other words they line up - just a double skin wall in between.
As long as I seal the hole for fire can I just not go through one of the back cut outs of one CU and straight into the back of the new one. 16mm singles 10mm CPC. 20 / 25 mm conduit. Fire proof foam / mastic etc.... job done.
That way I don't have to muck with going out of the first in conduit and through the wall and back into the second in conduit.
It looks fine to me but a little voice is saying can't do that......
I can't instantly think of any technical reason why not - use galv conduit and a bush each end and you don't even have a fire compartment breach. You wouldn't think twice about pushing through a brick wall to back-back an external socket, say, and this is materially no different.
Reply to the thread, titled "Back to back consumer units" which is posted in UK Electrical Forum on Electricians Forums.
South England
United Kingdom
Thread Tags
herman,
Rockingit,
