soulman
Hi, I returned to a property today for second fix, all was going well until i hit the sockets! The metal backboxes i installed, the fixed lug on one side would not hold the screw. The screw would just turn & not nip up. There was 6 in total out of 30 that were faulted. (Appleby)
Anybody got any ideas on how i could rectify this without removing the boxes.
Cheers
can you get in the lug from a fast a fix box and screw to the side of the box, can the 3.5 not be retapped, or can put ptf or insulated tape round the screw to make it bigger
You could remove the lug or bend it back ,drill a 3.5mm hole in the back of the box and tap it with 3.5mm tap , then put in an extension screw , then use a normal 3.5mm screw , but watch the length of the screw though, thats what I have done in the past,,
Cheers
get pliers and close up the screwhole slightly...then tap it out 3.5mm again...
When rewiring 60's houses I always save the accessory fixing screws,the imperial thread is coarser than a metric M3.5 and usually takes on a stripped thread. A stock of 'em on the van saves a lot of grief.
This is the difference between being new and being skilled and experienced!! Being able to think and work these sort of things out on your feet. Skill and experience doesn't only apply to the technical aspects of the job!!
I've been in this situation few times. I drill a 5mm hole in the back box in line with the lug then pack a couple of wood splinters into the hole. I then screw normal socket screw into it and it holds nicley
Drilling through the back of the back box would be my very Last solution, and normally only then, if the tab has snapped off the box. In the case of a new installation, not exactly what the customer/client is paying for though is it....
Get some socket screw extension studs (google them, should be a link to amazon) and use a removable lug from another backbox and screw the stud in, using the good lug as a washer behind the knackered one. Then tada! Works a treat for me everytime, no drilling or anything!
Cheers mate. Only spotted these studs by chance in a wholesaler ages ago and thought they'd get me out of a few situations with knackered lugs beyond repair, and they have certainly have! Definitely a necessity to have lying around in ya fixings box IMO
Never a disaster there is always a way round it the guys on this site are so talented in little problems like tis thats why we are all here the way I would do it as has probably been mentioned is b removing a unfixed lug and using it as basically a nut bit fiddly to get it on but it works a treat bugger for any one removing it in the future mind lo
Hi Mark80,
love this idea, just wondered though, can you still get a screw in the extension stud, as their won't be much room left from accessory to stud for a screw....
Yeah, you're basically hoping the backbox is not perfectly flush with the wall or you might struggle a bit. Sometimes I just have to cut the screw down to get it all the way in, but never had a problem yet TBH.
I always do as Mark says and use hexagon brass screw extenders , but put 2 x 3.5mm brass nut's pinched up on the back as well , ( get them from the wholesalers at the same time ) that way the extender will not work loose and just spin round if the accessories is unscrewed again .
You do have to be careful though as to the length of finishing screw to use as it has less space to go before bottoming out , and if not cut cleanly the threads will pick up on the brass extension and you are back to square one !
soulman
Durham
Backbox Disaster
soulman,
JD6400,
