Recently sorting out first fix for a loft extension for a friend and ran into a situation I don't often run into (I avoid new builds usually)
In the internal walls, they had the normal wooden studs, then one side was boarded 15mm thick OSB - and plasterboard screwed directly on top.
I assume it's to add structure, but it threw up several issues.
Since the OSB was covering one side of the studs, when the builders plasterboarded that side they just screwed to the board with standard plasterboard screws without checking where the studs were - so had to remove several screws protruding through very close to wiring in the studs.
Then the issue with back boxes - in the end I multi tooled the board out and clipped the back boxes to that, and left the plasterer to worry about the recess depth.
Is this a standard method these days? If so what's the 'correct' or easiest way to fit back boxes for the future?
Only other option I see would be to batten in advance for metal back boxes, or find some plasterboard boxes that can cope with the double depth.
I guess cutting a large hole in advance in the OSB would have been the better option, but it was boarded before I realised that.
