Bad Installation | on ElectriciansForums
Discuss Bad Installation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Lincolnshire
I was asked to write a report today regarding a poor solar installation.
There are two inverters. The left is wired out the dead side of a shared AC isolator while the other inverter is wired of the live side (from the meter ) feeding another AC isolator.
In my opinion one inverter would feed back into the other this way.
Also do the Samil inverters have much earth leakage to cause nuisance tripping if two wired in parallel. Samil technical couldn't answer that question today.
Any thoughts
thanks Ja
  • [ElectriciansForums.net] Bad Installation
Its not clear from the pictures and description but sounds like a radial circuit with 2 ac isolators (nothing wrong with that ) what size is the ac supply ? what size array ?
The inverters won't feed into one another .
Cant comment on the nuisance tripping . what are the ocpd characteristics ?
Its 2kw pv.1kw east and 1kw south. If I fit more than 1inverter I always sub fuse each inverter. Best practise for isolation and fault finding. Ocpd not fimiliar with that. They have blown 4 inverters up so far. So there is a fault some where
why didnt they use a proper inverter? you can have multiple strings feeding an inverter?
at only 2kw its only 1kw per string or 4 x250 watt panels per string.
one of the companies i did work for usually did around 10 per string (cant remember exact it was about 3-4ish years ago)
Yes like a dual MPPT inverter
Reply to Bad Installation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
