We have had builders in, who have stopped for Xmas.
My daughter tried to do a wash. The wash machine wouldnt. Its power socket is dead. I tracked
the supply cable to its source ( on top of an eye level cupboard) & found a really frightful example of bad wiring.
Later: I tried to insert a photo & "the file is too large for the server to process"
I dont know which possibility to believe:
1. It has been like that for 20+ years. Builder came up here, disconnected the WM's socket, (why? no idea). They must have seen
the bad wiring & didnt report it or
2. Builder was totally incompetent or
3. Builder is a qualified electrician & decided to do a bad job & hope nobody would notice.
There was no reason for them to do anything there at all. All they were supposed to do (electrically) was to extend the light circuit
into the extended
space. ( They have done this: good or bad job? I dont know). I suppose I really should get in a qualified elect. to check it all, but
I expect that (s)he will find all sorts of things that were perfectly safe & legal when the place was rewired many years ago but the
regulations have changed. And they will want to do a complete rewire: several ÂŁK & floors taken up & etc. Also I must try to be tactful in
approaching the builder as we want to remain on reasonably good terms; OTOH there may well be a bad electrician out there putting other
people's lives in danger.
So: If I decide to make a formal complaint, who should I complain to?
Please any other advice? Thank you
into the extended
