bahco screwdrivers | on ElectriciansForums
Discuss bahco screwdrivers in the Electrical Tools and Products area at ElectriciansForums.net
I baught a set rougly a year ago(ÂŁ30 I payed for them from that exact site! :( ) Ive had no problems with them, although the small terminal driver snapped a few weeks ago though. Highly recommended screwdrivers, CK Sensoplus screwdrivers are also good, but they are costly.
Hope this helps, even if i did babble on :D
Tom
Used these at southern electric agree with others they are good and like others have said price is i wont swear either so their cheap as chips as the vicar would say !
thanks everybody for your help.just ordered a set. now i'm after a decent pair of cutter that are not too gimmicky but do the job.
What type of cutters are you looking for? I personally use:
Knipex 70 06 160 for cutting any cables up to about 8mm with ease. http://www.knipex.com/fileadmin/sit.../KNIPEX/Produktfotos/web/normal/70061604k.jpg
Also for singles cables and other similar tasks which require cutting, stripping and the use of ferrules i use Knipex 13 01 160 http://www.knipex.com/fileadmin/sit.../KNIPEX/Produktfotos/web/normal/13011604k.jpg infact I would go so far as to say, they are the best tool in my box, very versatile and very well built
Hope this helps
Tom
No, it didn't begin with an "s"
Although it does have four letters,begins with a "C" ends in "P" and means the same as the word that begins with an "S"
Da Vinci code solved!
God I feel dirty now,using that shocking language!
Reply to bahco screwdrivers in the Electrical Tools and Products area at ElectriciansForums.net
You can buy the wera ends in singles for replacing broken and worn ends which is nice
If in doubt, hit it with a hammer and see if it gets better. sometimes the simple solutions are the best ones!!
