Balancing a 3 phase load | Page 2 | on ElectriciansForums
Discuss Balancing a 3 phase load in the UK Electrical Forum area at ElectriciansForums.net
G
gerard
I have a question on balancing a load. We have 3 cabins with the following loads: 10kW, 8kW and 3kW, supplied by a three phase supply. Each cabin will have it's own supply. Is there a simple way of balancing these loads, or is it possible?
I have found out that the phases are not balanced throughout the building. All I can do is wire new loads to the phases with smallest loads
Be careful here when assessing the existing load, if you can get an idea of the design load of the existing not just a measured load as you may have clamped at a period that might not show a true reflection of the normal trend... once your happy with your averge load per phase then yes do as you suggest to rebalance the existing with your new loads.
Stick a data logger on the existing supply for a week and get a proper look at what is going on
A bit OTT tbh unless its fluctuating alot and the existing circuits are hard to identify and trace... a weigh up on of the existing circuits should be enough to guess if your measured reading is reflective of the nature of the design load.
Edit ... the OP already has the equipment so seems the better option - most don't posses this equipment and could be expensive to hire out.... this round to you dave ;)
It depends how big and complex the installation is, and how accurate you want/need to be.
I am used to balancing generator supplies at festivals/events so am very mindful of maintaining good balance at all times, bearing in mind the nature of loads as well as design currents.
And for small installation some home energy monitors work as reasonable data loggers when high accuracy is not key. I've got 3 OWL transmitters with 200A CTs I picked up on eBay for next to nowt along with a USB receiver to download/monitor the data. They work quite well when my proper power quality analyser is already in use.
Reply to Balancing a 3 phase load in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
They do a cy type with pur coating and it is even tougher but is shielded
