Ballast confusion.... | on ElectriciansForums
Discuss Ballast confusion.... in the Australia area at ElectriciansForums.net
J
jules27
Morning I have Ten ballasts to install and the customer picked these up for me , but I'm not sure about these . surely there should be 3 in (L,N,E) and 4 out (to the tube)?? there only appears to be four connections in total. Prob simple for yourselves
Cheers
  • [ElectriciansForums.net] Ballast confusion....
Thanks for the reply , was going to earth the casing . but the point is i need a seperate starter ? can i get this in one unit as i was planning to install the ballast behind this shade ( see pics)and am not sure how i would fix the starter .I am fixing to an aluminium wall
[ElectriciansForums.net] Ballast confusion....[ElectriciansForums.net] Ballast confusion....
Reply to Ballast confusion.... in the Australia area at ElectriciansForums.net
Good point James. It would have been nice if the manual had mentioned which of the leads were being used for what though. It simply shows the LNE...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
