ballast of flouresent fitting | on ElectriciansForums
Discuss ballast of flouresent fitting in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
light fitting has just stopped working, ihave checked and theres still voltage present at fitting, so.... my question is how would you test a ballast and what does a ballast actually do??? thanks if your reading this instead of bed with you gf/wife/boyfriend
seems great and i do know is 58w fitting, is there much in changing one, just seen line and neutral comming out and into connector block. probably just a screw holding it in place, i hope.. thye dont hold a charge or anything do they???? i dont think so but il ask, aint had a shock yet
dead on told her new fitting was ÂŁ30 in homebase which she was happy enough about, would you say is very likely the ballast, and theres no way of testing old 1? to give me a yes its broken before i order thanks for the conversation
i just go homebase half the time, i have few things to get this week so might go cef while im over that way monday.. 1 more question there is light fittting at front of house with the connection in connector block with just tape around, it is under a porch, so cant get wet, would indoor junction box be suffice for this in your eyes.. the whole house needs stuff done but im saving that for next year if i join a scheme
Reply to ballast of flouresent fitting in the Australia area at ElectriciansForums.net
K
Advice needed - questions before getting new bathroom fitted Hi all, hope this is okay to post. Just over a year ago, I took on my dad's old...
KamikazeBob
K
@Megawatt can you help
