Ballast wiring | on ElectriciansForums
Discuss Ballast wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
O
One_of_them
guys I've got a Tamsh**e fitting where I think the wiring maybe incorrect. This is a wiring diagram from Tridonic's website of the ballast....
[ElectriciansForums.net] Ballast wiring
Basically on the drawing, following the cable from terminal 9 flows through all the lamp pins until it reaches terminal 16. However my lamp, the cable from terminal 9 goes into the lamp and out the other end but to terminal 11?????
terminal 14 goes through lamp and out to terminal 16???
(sorry cant remember the rest of them as im at home now but can check tomorrow if needed)
just seems a bit wrong to me? Can any lighting guru's help out?
The wiring is correct for a Tridonic ballest , sorry just re read and that is tridonics schematic . if it is a tridonic ballast and a three tube fitting go with tridonics wiring diagram
Reply to Ballast wiring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Definitely looks like the cpc (earth) has been sleeved and used as a neutral conductor, this is not permitted. You are going to need an...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
