ballast | on ElectriciansForums
Discuss ballast in the UK Electrical Forum area at ElectriciansForums.net
T
toptrics
Hi guys what is the difference between an electronic ballast and a standard ballast
A standard ballast has a coil of wire (sometimes 2 coils) around a ferrous core, an electronic ballast uses solid state components to do the same job, they're very similar in design to a phone charger or laptop power supply but use modulation in the output stage to supply the lamp with high frequency power.
Electronic ballasts have many advantages, they're; cooler running, quieter, more efficient, lighter, cheaper, less prone to lamp flicker, self starting and less likely to cause a fire when the lamp fails.
Inductive ballasts have a few advantages, they're less sensitive to surges, possibly more robust and older electricians like them because it's what they grew up with.
Reply to ballast in the UK Electrical Forum area at ElectriciansForums.net
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
