smp
Hi,
I have some 4 pin 28w 2d emergency fittings that are not working properly, consisting of electronic ballast and then em module. Is there any way of detecting which unit is faulty as with the light operating ok in normal mode,I changed the module first as the fitting wasn't operating on test, but the fitting still isn't working, so now assume it's the ballast (cheap moulded unit with fixed leads)
Any help would be appreciated as I have around 60 of these fittings to look at!
Regards,
smp
Regards,
smp
