ballasts | on ElectriciansForums
Discuss ballasts in the Australia area at ElectriciansForums.net
spats
Hi
How do i test a ballasts output is correct, the fittings lamp is ok and it is not a supply problem.
regards mark
What sort of ballast?
Digital.....I know of no way of testing these....if the supply/lamp/connections are proved ok it must be the ballast as there is nothing else.
Choke(2 wire switch start)....test live in and live out....you should get full voltage on both.
Ballast...old style 4 wire....I dont test them.....same comments as digital....check everything else and eliminate.
Reply to ballasts in the Australia area at ElectriciansForums.net
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
I know it was a few years ago when LED was mor in its infancy but we looked at a job that had designer flo light fittings in a big bar. The...
