band D on an epc with panels fitted | on ElectriciansForums
Discuss band D on an epc with panels fitted in the Talk Electrician area at ElectriciansForums.net
F
feebs73
Hello all
Can anyone answer this question please?. can you get the top feed in tariff if you make D rating with solar panels fitted.
Many thanks
feebs73
Yes, the EPC submitted with the FiT application just has to be the most recent one.
It is probably worth noting that this is something that may change next year as it is one of the items that DECC consulted on changing.
Thanks TedM
Reply to band D on an epc with panels fitted in the Talk Electrician area at ElectriciansForums.net
Useful to know. In my case there will be 150x150mm trunking at top/bottom and almost certainly I will be using tri-rated cable, probably 70mm...
Yea I do It was more the spd at solar end I was more enquiring about than rcbo just wanted to confirm it for my own sake as I was questioning...
