Banjo. | on ElectriciansForums
Discuss Banjo. in the Australia area at ElectriciansForums.net
O
OhmSweetOhm
Straight forward question, is there any point putting a banjo on one end of a cable and not the other when glanding both ends? Also do you need the banjo if one of your cores is an earth?
I always earth at least one end via the banjo bolt to the CPC. If its a metal box the box will also be earthed to the CPC.
sorry whenever I hear the word Banjo I just think of cowboys.......dudu dum dum dum....deedee dee deee dee....bing bing bing dum dum yee haaaaww dum dum dumdum deee deee wooooo yeee hawww ....
woooo woooo
[ElectriciansForums.net] Banjo. [ElectriciansForums.net] Banjo. [ElectriciansForums.net] Banjo.
so, use earthing nuts. if you don't like banjos. bedtter than just twisting a bit of wire ( sorry malcolm ) cable under the nut.
Reply to Banjo. in the Australia area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
