bannanas and voltage | on ElectriciansForums
Discuss bannanas and voltage in the Australia area at ElectriciansForums.net
i=p/u
Northern Ireland
was sent to check two cctv cameras down on friday. when i got there the boxed had the power box had been knocked off wall and the cables had grazes and splits in them. i fixed fw connections and done continuity test as is a long run. and continuity was fine. when i powered up again i was getting 247v between L-E but between L-N i was only getting 135v. now help me with this simple query please .
isit normal for 12v powerpacks to burn out in your expieriences... thanks if you wise me up
when you test continuity, you are only applying a few volts dc. as soon as you apply a load any poor connection on the neutrasl will show up. i has exactly the same thing on a house ring the other week. plug in an extensin lead with neon, the neon lit. as soon as a load was plugged in, N went to 110V, ( floating ) and turned out to be poor connection s in back of a socket.
And there was me, ...thinking i was a Man of the World!!! Please tell me more about this form of Bondage?? ...lol!!! :confused5: :camera:
It's all about nipples, clamps, screws, ties and plugs.
All available from a good electrical wholesaler! ;)
Reply to bannanas and voltage in the Australia area at ElectriciansForums.net
