barba shop lighting | on ElectriciansForums
Discuss barba shop lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
1983
I would like to change the bulbs for an recessed 4 x 18w modular fittings 600MM x 600MM TO 36W FITTINGS. THERES 12 modular fittings IN A BARBA SHOP. THEY WOULD LIKE IT MORE BRIGHT IN THERE. THE MCB IS 16AMP WIRED IN 1.5MM T&E. would this be ok to do? i worked out the ib would be 13.51amps does this mean i have 2 also change the switch as well? any advice would be much apprecated thank you.
Reply to barba shop lighting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you... I'll get up there have proper look, this was just a 1st glance !
Electric hob/oven range was installed years ago, runs on 2 x B32 MCBs to 'House' (sub)consumer panel, runs to oven on 2 x T&E. Kitchen is being...
