bath room fitting | on ElectriciansForums
Discuss bath room fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
Hi all
came across these low voltage light above bath but over 2.25m so out of zones
what are your views as there is no IP rating for them and the room having a moist atmosphere i would have rejected using them but could you defend such a choice other than the moisture issue
Aurora - Technical Datasheet
Well you could argue that they are elv, and so installed outside zones should be acceptable. But they should be suitable for the environment which they are not.. So I would agree that they shouldn't be installed in that location. It may be a good idea to contact the manufacturer and ask them directly...
Reply to bath room fitting in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes, that was actually something making me uncomfortable too, the bonding of it all. I need to have another look at it, I'm not sure if the...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
