A
///ajd
Hi,
A while ago, I installed an IP44 rated (Zone 1/2?) light in my bathroom - this replaced an existing 240v light.
Here is a picture...
...it is not over the bath as such, but it is near the edge. It is clearly >225cm from the floor. What zone is this, given the regs below (I know zone 3 has gone now)? The treatment of the ceiling is a bit vague in the regs the way I read them.
Just had an electrician round who says it may need to be something like IP56 - but he was a bit vague. I appreciate the showerhead complicates matters somewhat, but I am pretty sure I'm going to decommission the shower when I rent the house out anyway (mainly from a fear of tenants causing general water damage etc.).
So opinions please - both with/without shower in use.
I would really appreciate, if you feel there is a problem, what solution you'd recommend - i.e. type of light, from where, how fitted etc. for minimum cost & disruption to the existing holes in ceiling and wiring etc.
Thanks in advance!
James
Thanks in advance!
James
