Bathroom Downlighters | on ElectriciansForums
Discuss Bathroom Downlighters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A
AA410
Hi Good people advice please is it good practice to wire 240v downlighters in twin/earth or JB with HR flex in the loft i was alway told that tw/e is for fixed wiring not flex:confused: advice on this please many thanks
I take my twin into Wagos them if not already done, wire a length of flex from me downlight into the Wago.
I then usually use a choc box to enclose the Wagos in, using cable ties as a cord grip.
Quick to install and much cheaper than these so called quick connectors that you can get.
I've used both before, depends on the job and what I have to hand. If fitting from below and putting back up through the holes I'll use 2 or 3 core flex as easier to bend and handle, if up on a loft fitting for the room below I'll sometimes use t&e, probably just because you can easily do a tidy install when you can see it in front of you. Can't see it matters either way tbh
Flex is only designed for short runs!!!!....Solid (T&E),obviously can carry a greater current over a longer length,if down lighters are off transformers,remember the output is D C,thus the current rating of the cable / circuit is increased....Something a lot of ""SPARKS"" seem to forget about!!!
Always learning....Always willing to be proved wrong....Just not by the Fists!!!!!:)
Reply to Bathroom Downlighters in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
Can anyone help me identify these bathroom taps please? Hi Can anyone identify the make and model of these taps please? We have one dripping...
Richt5a
R
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
