Bathroom fan, 3 pole isolation or fused spur? | on ElectriciansForums
Discuss Bathroom fan, 3 pole isolation or fused spur? in the Australia area at ElectriciansForums.net
P
Penance
Just picked up a timed fan and 3 pole switch. Fan is 4" 20 watt. I was going to run 3 core and earth from 3 plate light via 3 pole switch and to fan as per normal.
Just read manufacturers instructions and it says must be a double pole fused (3 amp) spur. Can't see the logic to that.
What would you guys do?
I know it's maybe a daft question but this will be part of my assessment.
Manufacturers instructions should be followed
It would cost them to put one in the fan, so they put it in the instructions instead,its cheaper :rolleyes:
6 amp mcb and 3 amp fuse will do battle to see which would go first,so probable waste of time
Anyway,if you insist on using a light to operate a fan :eek: (I personally never ever do so )then what you could do is use the switched fused spur to supply the light and your 3 pole islostor for the fan off the light as you descibed
Des, it's a small downstairs bog with no window so as far as I'm aware it needs a timed extractor that operates when the room is used. So a fan run from the light seems the obvious solution no?
Interested in how you'd do it.
So then, I should put in a dp fcu then?
If so should I go light > fcu > fan or would you put the 3 pole switch between fcu and fan?
Seperate pull cord tucked away in the corner
My veiw is who wants a ventilation unit vibrating the rafters in the middle of the night when all they wanted to do was have a quick leak
but which feed to the fan do you fuse at 3A? the permanent or the switched or both. only way to do both is to fuse the permanent line to the light.
Tel, that was what I thought too, one fuse and two lines so do I ---- a coin.
No window in the room so even a daytime download would need the light on unless you wipe in brail!
Instructions are pretty generic to all fan models and I wonder if the dp fcu should only apply to the 2 wire switched fan?
Feed the swiched fused spur 3 amp to load side
From the load side,feed the fan permant live,from the load side also, feed the pull cord
The pull cord will manually switch the fan and switching it off will set the timer in motion
All connections made in the S/f spur
that's fine des, as long as you're not feeding switched live from the light.
Reply to Bathroom fan, 3 pole isolation or fused spur? in the Australia area at ElectriciansForums.net
Echo above, as someone who's probably similarly inexperienced I have set myself up a per point spreadsheet and whack it all in there. This has...
