Bathroom fan and light switch | on ElectriciansForums
Discuss Bathroom fan and light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
gary johnson
Hi, I have a fan in my bathroom which has two wires to the pull switch they are both red, i want to remove the pull switch and wire to my light switch. The light switch has three wires red,black and green. my house s approx 17years old is this possible to do. do i need a new light switch. both are pull swtiches, so once complete when the light is pulled it will turn the light on with the ceiling lamp
thanks for looking
any part p registered domestic installer electrician in your area should have no problem easily doing this within a day for you. this could be with or without making good though depending on who you use and price etc. make sure the work is certificated.
Is this a fairly old fan as well?
You could get a fan with a delay timer etc and wire from your light fitting if it's a loop in type. But is it really worth the hassle?
This work is in a special location and so would require notification to your LABC.
It may be cheaper in the long run to get a certified spark in to do it for you.
Also, normal light switches are not permitted in certain zones in the bathroom, which is why there is a pull switch.
If you do wish to install a normal light switch it would need to be fitted outside the bathroom door.
Just to clarify - Are you saying that you have 2 seperate pull cord switches in your bathroom, one for the fan only and one for the light?
Reply to Bathroom fan and light switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
